PXI
PXIe-8370 to control PXIe-1085 (24GB/s)
Hello all,
Would like to ask about particular configuration: is it possible to control PXIe-1085 (24GB/s) some sort of x8 PXIe chassis through PXIe-8370/PCIe-8371 that is x4 PXI Express Controller.
Note: I'm aware about PXIe-8381/PCIe-8381 that dedicated for PXIe "x8" chasis, and fits better for PXIe-1085. Question trigered by interest in utilising PXIe-1085 chassis with PC that has only PCIe x4 slot avalaible.
Best Regards,
Roman Pilipenko
(2,694 Views)
Accepted by topic author RangerOne
Hi Roman,
Your chassis should be compatible with any MXI form (x1/4/8), so long as there are enough lanes on your PCIe counterpart.
On a side note, If you look in the user manual for your card (MXI-Express x4 Series User Manual), you may be interested in the data limit per lane "The link can transmit at a rate of 10 Gbps"
(2,654 Views)
