02-01-2017 02:30 AM
I have a question about Pin Nr. 14 at the Connector of the PXIe 6363 Module:
(I am not sure if it is the correct information I found in the datasheet).
Is it possible to connect there a Sensor which consumes 60 mA @ 5 V?
Thank you very much!
Solved! Go to Solution.
02-01-2017 02:53 AM
According to the spec, that pin has a 1A current limit. So you can use that to power your sensor.
02-01-2017 03:40 AM
Ok, thank you very much for your help!
