04-26-2014 04:17 AM
I want to do some test by using PXIe-5451 AWG, and my 5451 AWG is in Remote Systems. However, I can not change the output frequency of 5451 AWG when I use the Test Panels. As u know, FGEN can not be used in Remote Syestmes. So, what can I do..
Thanks.
Vincent
04-28-2014 06:02 PM
Hi Vincentum,
As this KnowledgeBase arcticle confirms, there isn't a way to use FGEN SFP on a Real-Time systems. In order to control the output frequency you will need have a target for the 5451 in a Real-Time project, then create a VI under this target and use the FGEN palette functions to achieve this functionality.
01-29-2015 09:51 PM
Hi matt
Thank you very much for your nice reply. Now, I want to ask that can I change the output signal resolution of AWG PXIe-5451 when I create my VI in a Real-Time project. As you know, it is a 16-bit AWG, now I just want to use the about 12bit resolution signal generation.
Vincent
01-30-2015 11:03 AM
Hello Vincent,
According to the Signal Generators help manual, the NI PXIe-5451 stores arbitrary waveforms in memory as signed 16-bit digital words. On the NI PXIe-5451, the entire 16 bits are sent to the digital gain circuit, the OSP and the DAC.
May I ask why you are wanting to reduce the resolution of your output signal?
Best,
02-03-2015 09:26 PM
Hi Anderson,
Thank you for your kindly reply. I am doing some contrast measurement by using some signal with different resolution. So, I want to know if I can use this NI PXIe-5451 AWG to generate the different resolution output signal.
Best Regards,
Vincent
02-04-2015 10:31 AM
Vincentum,
The AWG will always represent the data using 16-bit words, but you may be able to manipulate the data yourself to appear as less resolution (for example, take your data set and round values to the nearest X).
