04-09-2014 11:05 AM
Hello All,
I am wondering if it is possible to set 2 distinct carrier frequencies on the PXIe 5451, which is a dual channel AWG. I have fiqured out how to take a waveform and add a carrier frequency, but eventually I need to be able to take two completely different waveforms, put each waveform on a different carrier frequency, and play each out of a different channel. Does anyone have any ideas?
Thanks!
04-10-2014 12:32 PM
Hi lyind8,
Here is a different forum post that appears to be a similar question. See the VI attached on the last post marked as solution:
I think you could use this to manipulate and send out two different waveforms on the two channels. Good luck!
