PXI
PXIe-1082, PXIe-8135RT, MXI, and Signal express
I was dismayed when I realized I cannot use SignalExpress from my host laptop to my PXIe-1082 chassis with its PXIe-8135RT controller.  So I have a few questions as to options...
Can I put a PXIe MXI slave interface into slot 4 of the 1082 chassis (The timing slot)?
Can a PXIe MXI slave interface coexist with an active PXIe-8135RT (LabView RT) controller on the same chassis) or would I have to pull the controller to use the MXI interface?
Would SignalExpress on my host work with an EC MXI card?
If MXI isn't feasible, if I were to install LabView (I have the platform bundle) on a second hard drive to swap with my RT PXIe hard drive, would I have to buy another set of licenses?
All I want to do is have the option of using Signal Express with my PXIe hardware, but it's looking like there's no easy option.
XL600
(2,430 Views)
Yes you can use a MXI system with a RT controller.
Take a look at this document about MXI configuration with RT: http://digital.ni.com/public.nsf/allkb/6DD52E97DE5D9333862571BD0073CF3E?OpenDocument.
(2,375 Views)
xl600,
You can't use MXI to connect to the chassis from your laptop AND from a PXIe-8135RT controller.  There are 2 ways to use it:
1. MXI from your laptop to a MXI card in slot 1 of the 1082 (replacing the 8135)
2. MXI from slot 2+ to another chassis, where there's a MXI card in slot 1 of the 2nd chassis (= add a chassis, still doesn't connect to your laptop)
I don't think these are what you're wanting to do.  I don't know about the licensing so I can't comment on that.
- Robert
(2,372 Views)
I see.  That makes sense, but it's still unfortunate signal express can't handle this.
thanks,
(2,369 Views)
