I am trying to route the ao/sampleclock signal to the ai/sampleclock signal on a PXI-6259 DAQ card. The routing table in MAX shows that this is an indirect route through the trigger bus. Also, this used to be no problem before today...
This morning, I moved a bunch of cards around in my chassis and added some new ones. When I booted up, all the cards were recognized and I tried to run my app but the error popped up:
So I checked the chassis in MAX, and it had a little X by the icon and said something to the effect of "chassis unavailable during PCI backplane initialization". Unfortunately, I didn't have the foresight to write down the exact text. I deleted the chassis identification, and re-identified it, did a reboot, and now it shows as "chassis properly configured", but the error still persists. The daq card test panels work, and the other cards seem to function correctly, just routing the signal doesn't work. I'm not sure where to go from here...as I mentioned, this was no problem before moving cards around, and I don't think it should be an issue.
My setup is:
PXI-1042 chassis with PXI-8310 Starfabric interface controller (connected to laptop)
PXI-6259 DAQ card in slot1
other devices in remaining slots
LabVIEW 7.1.1
MAX 4.1.0
DAQmx 8.3.1f0
Any help would be great. I'll gladly provide any more information that is necessary.
Jon
Message Edited by bigg_jon on 04-09-2007 12:04 PM
