06-27-2017 07:12 AM
Hello
On the DIO96 channels, the GND in the connectors is not connected to the metal casing of the board.
However of the one that puts the card in a PXI 1073, it connects the GND to the ground.
Is it possible to remove this link in the PXI?
A rider to remove for example?
Thank you in advance.
06-29-2017 10:23 AM
What product precisely do you use ? And what do you want to do ?
Kardio
06-30-2017 02:38 AM
I have a NI PXI 1033 chassis and when I put a NI PXI-6509 in it, it connects its GND to PXI power ground. This is not common as demand but I want to know if we can disassociate the GND from the 6509 to ground chassis knowing that I will read it further with a resistance.
