You cannot change the PXI VISA instrument descriptor for any PXI
devices. However, the you will be able to use a VISA alias for these
devices. Then you can export your MAX configuration file for use on another PC.
PXI is built off of the CompactPCI platform,
each slot is essentially a PCI slot. When the PXI system first boots
up, the BIOS on the controller enumerates all of the PCI busses and
slots in the system. This enumerated information is what makes up the
PXI VISA instrument descriptor. As such, this information cannot be
changed.
For more details on PXI VISA instrument
descriptor, please refer to
KnowledgeBase 2IJ896LS. That KnowledgeBase goes into the details of how the enumeration is done and the assignment for each chassis.
The hardware description folder found by navigating to your National Instruments folder and then PXI hold the descrition for all the PXI slots and bridges.
Christian A
