PXI
PXI bus number change(1075 to 1085)
I changed the chassis PXI-1075 to PXI-1085 and moved all the cards to the new chassis. However, I found that the PCI Bus number automatic changed( for example, for slot14, it changed from 20 to 22).
My question is: can I change the Bus Number the same as the old chassis(1075)? If yes, how? Who in the system is defining this number? Thanks.
(2,382 Views)
1.put the devices in the right slot
2.then rename the devices in the MAX http://digital.ni.com/public.nsf/allkb/F80F517828A190C186256E58005CD0A7
(2,249 Views)
