Thank you for your help. We found out that we use PXI-8156, which doesn't support RT-engine.
Because of the poor hardware capabilities (slow processor, lack of RAM) we still want to create a data aquisition system that would process aquired data remotely (a better PC on the same subnet). As we found out, one way to do that is by using RDA (Remote Device Access), which works without problems.
But the problem still remains: Windows loads many drivers that we don't need. It might be better to use DOS or some NI operating system.
Do you have any suggestions, how we could achieve remote processing or remote access via ethernet on current hardware?
Hardware specification:
- PXI-8156 (233 MHz , 32Mb RAM)
- PXI-1000 case (box)
- DAQscope 5102 (oscilloscope)
- 4060 Digital Multimeter
- MIO 6070E (multifunction input-output)
- IMAQ 1408 (Image aquisiton)
