PXI
PXI-MXI chassis times out only in MAX
Hi all,
I am using a PXIe-1062Q chassis, connected to my laptop via a PXIe-8361 and the MXI express card. Recently, on opening of MAX, the system times out and an X is shown on the PXI chassis. This happens whenever I start MAX, oddly though, the system works correctly if I access the hardware via LabVIEW and not MAX. If I try to access the hardware in LV after MAX times out, LV also times out with a DAQmx hardware error.
This issue started yesturday morning, another interesting fact is that before yesturday morning, on a fresh boot/reboot MAX would correctly identify the chassis and cards, but if I waited a while and then opened MAX, the system would timeout.
I am leaning to DAQmx (14.5.1) timing out in MAX. When the timeout occurs, I can no longer look at tasks, Network Devices (2 LXI supplies), or software. When I click one of those items, the down arrow disappears and nothing is shown below them as a subset.
Should I reinstall MAX? DAQmx?
Thanks!
(3,975 Views)
Hi ademedeiros,
This sounds like there may be a corruption somewhere within NI MAX. My first suggestion is to try resetting your MAX Configuration Database:
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9?OpenDocument
If you are still seeing the issue past this point, try doing a full reinstall of NI-DAQmx.
Libby B.
Applications Engineering Specialist - RF Wireless
(3,920 Views)
