We are using a PXI 8186 and it booted fine until yesterday when it
sudendly crashed part of the way into the boot and then rebooted into a
safe mode. Here is a copy from the log of what we get:
System log started Fri Jul 29 10:34:23 2005
---------------------- NI-Serial v2.5 for LabVIEW RT ----------------------
COM1 - COM2 | PXI Controller Built-In Serial Interfaces
Welcome to LabVIEW Real-Time 7.1
*** REGISTER DUMP FROM EXCEPTION HANDLER (code 18) ***
EAX = 0x0191E800 EBX = 0x0191E800
ECX = 0x0191E800 EDX = 0x00214C00
ESI = 0x00000020 EDI = 0x00000000
EBP = 0x00A19110 ESP = 0x00a18e18
CS = 0x0018 DS = 0x0020 ES = 0x0020
EIP = 0x001714cc
Thread name: <unnamed>
Thread stack base: 0x009FA000 stack size: 131072
Call Stack:
Level 1 : Code pointer: 0x001716D7 Stack Base: 0x00A19808
Level 2 : Code pointer: 0x00A488B0 Stack Base: 0x00A19820
Level 3 : Code pointer: 0x00A59C93 Stack Base: 0x00A19AAC
Level 4 : Code pointer: 0x00A3DA2A Stack Base: 0x00A19AC4
Level 5 : Code pointer: 0x00A3DF64 Stack Base: 0x00A19C0C
Level 6 : Code pointer: 0x00A3DC74 Stack Base: 0x00A19C44
Level 7 : Code pointer: 0x00A3DB94 Stack Base: 0x00A19C60
Level 8 : Code pointer: 0x00A3DBF4 Stack Base: 0x00A19F10
Level 9 : Code pointer: 0x009984EB Stack Base: 0x00A19F64
Level 10: Code pointer: 0x0098E855 Stack Base: 0x00A19FA4
Level 11: Code pointer: 0x0098FA3A Stack Base: 0x00A19FC0
Level 12: Code pointer: 0x0011C92D Stack Base: 0x00000000
DLLs loaded:
DLL: EMBLVIEW.EXE First export address: 0x00307040
DLL: FTPSERVE.DLL First export address: 0x0029DBE8
DLL: I8254X.DLL First export address: 0x0029B003
DLL: I8255X.DLL First export address: 0x002DF6CD
DLL: IRDA.DLL First export address: 0x00628389
DLL: LIBICONV.DLL First export address: 0x00274430
DLL: LVRT.DLL First export address: 0x00348B20
DLL: MXS.DLL First export address: 0x00A220C2
DLL: MXSEMB.DLL First export address: 0x008D2E84
DLL: MXSIN.DLL First export address: 0x00A3DB5F
DLL: MXSUTILS.DLL First export address: 0x00843102
DLL: NIDMMU.DLL First export address: 0x01986010
DLL: NIICFQSV.DLL First export address: 0x01931A81
DLL: NIIDQSVR.DLL First export address: 0x00B83210
DLL: NIPALP.DLL First export address: 0x00685F67
DLL: NIPXIRMP.DLL First export address: 0x00990233
