Maybe this question is bit primitive, but ...
Is it possible to set Current output on PXI-6733 High-Speed Voltage Output?
I have tryed and i think answear is no, because i've got this message
DAQmx Error Selected physical channel does not support the output type required by the virtual channel you are creating.
Create a channel of an output type that is supported by the physical channel, or select a physical channel that supports the output type.
Property: DAQmx_AO_OutputType
You Have Requested: DAQmx_Val_Current
You Can Select: DAQmx_Val_Voltage
I've tryed it this way:
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOCurrentChan(taskHandle,"dev4/ao0","",0.0,0.2,DAQmx_Val_Amps,""));
DAQmxErrChk (DAQmxStartTask(taskHandle));
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
and error gave me command DAQmxCreateAOCurrentChan.
On the other hand if i try to set Voltage output, everything works just fine.
Thanks Michal
