PXI
PXI-6527 and PXI-6025E not recognized in MAX (RT-PXI)
These cards from an older system that ran Labview 7.1, now installed in a new RT PXI, but they don't show in NI-MAX.
Using Labview 2015 and NI-DAQmx 15.1, Windows 7-64bit
I've tried everything so far, just cant get them to show.
Can't install traditional DAQ, cause 64bit OS does not support it.
My guess is NI-DAQmx 15.1 does not support these cards ?
(4,195 Views)
The cards should be compatible with 15.1, according to the readme.
http://download.ni.com/support/softlib//multifunction_daq/nidaqmx/15.1/readme.html
Are you able to see the controller in MAX? Did you install RT support with the DAQmx 15.1 driver? Sometimes those options are unchecked by default during installation.
(4,165 Views)
Accepted by topic author morngoose
Turns out the PXI controller was not compatible with the PXI chasis, the local NI agent made a mistake.
NI now replacing the chasis for me
(4,083 Views)
