02-28-2008 11:13 AM
03-06-2008 07:13 AM
03-10-2008 06:14 AM
I've read PXI-6123 specifications, but I'd like more detail on how I might synchronize the measurements. I notice there are hardware trigger lines, but had hoped I could synchronize the acquisition of all 72-channels in software. Do you know of any NI literature that would give me an indication of the synchronisation options and the performance I could expect from each? I imagine you can SW or HW sync, and they’d be a known performance for each option.
thanks for the quick reply to my first post.
03-11-2008 06:39 AM
03-11-2008 12:31 PM
The NI-6123 is an "S Series Card", The "S Series User Manual" describes the functions.
http://digital.ni.com/manuals.nsf/websearch/55C6859BE86BA5A88625724200525582
The PXI-6123 can use the "PXI Trigger Bus" but not the "10 MHz Backplane Clock" or the "PXI Star Trigger", it can use the "Real-Time System Integration Bus (RTSI)" but only up to 7-cards max, my app requires 9-cards.
When I software trigger the start of my 72-channel acquisition, each card will receive the trigger on the PXI-bus on the designated line e.g. trig line 0. From that moment in, each PXI-6123 will be running independently using it's own onboard base-clock accurate to 0.01%. Assuming it's 0.01% per sample, by the end of my 1-second acquisition, i'll be a maximum of 100micro-seconds out on the sync between any two channels.
This is probably okay for this application, but it seems the 6123 is good for simultaneous sampling of up to 8-channels, but not the best NI product for synchronising 72-channels. Although it does appear to be the lowest cost option for this application.
03-12-2008 12:34 PM
