09-05-2007 03:20 PM
09-06-2007 04:15 PM
01-14-2008 12:26 PM
01-14-2008 03:24 PM
Hi Chris,
Having 10 dB more noise is expected since your attenuation is 10 dB higher, so that part is normal. If your digitizer is innocent, then we have two options:
A: Use another spectrum analyzer to look at the IF output of the 5600.
B: Use the digitizer to validate the fact and call NI for repair the 5600.
Hope this helps you get going,
01-14-2008 04:10 PM
Geraldo,
I used a second PXI chassis (identical configuration) to bypass the 5600 in question. All tests were done using the SAME 5421 and 5620. On each PC, I used the RFSA Demo Panel to confure the 5600s on both PXI-1042 in an identical manner. The results in the figures compare the suspect (bad) 5600 and the "good" 5600 for two different frequency spans. The spurious signals appear only in the 5-20MHz span and NOT in the 5-25MHz span. I fed the output of the 5600 into a benchtop HP89410A Vector Signal Analyzer. Yes, the frequency spurs are real and disappear when I change the RFSA Demo Panel span.
If you don't suspect a faulty PXI chassis, I'll physically swap the 5600s between the two PXI and see if the problem follows the module.
Chris
01-14-2008 04:12 PM
Gerardo,
I also promise to spell your name correct one of these times!
Chris
01-16-2008 05:17 PM
Hi Chris,
Thank you for your consideration.
So, these spurs are real (IF output of 5600) when no RF input and you change only the span on the demo panel. The software call might be tuning into a bad band. This is really odd behavior and you should return the board (ni.com/support will place you on front of the queue).
One more thing, what is the reference level setting in those screenshots? You have a warning message but I cannot read the Hex code.
Thank you for all this information,
01-17-2008 02:53 PM
Geraldo,
Yes, real and exist even with no input.
I wish I knew what you meant by this.
I'm running a conversation in parallel with another AE to get an RMA.
The HEX code refers to the ADC overload caused by the spurs. Here are three more screen shots of the RFSA Demo Panel with NO INPUT, three different reference level settings.
Chris
01-17-2008 03:08 PM
Hi Chris,
You did it again (Geraldo spelling) don't worry about it.
Basically, the 5600 driver tunes in two steps sizes: 1 MHz and 5 MHz and my thought is that the driver is re-tuning (for different spans). Regardless of this, keep the conversation with the AE and hope you are up and running soon.
01-17-2008 05:46 PM
