Hello Maggie_ok,
Thanks for posting in our Discussion Forum.
Do you really need to generate the
a synchronization signal? Have you tried using NI-TCLK to synchronized clocks?
NI-TCLK is usually the easiest way to synchronize signals within a PXI-chassis. You can find some useful information here:
Using NI-TClk to Synchronize Signal Generators
http://zone.ni.com/devzone/cda/tut/p/id/5501
National Instruments T-Clock Technology for Timing and Synchronization of Modular Instruments
http://zone.ni.com/devzone/cda/tut/p/id/3675
If you are using LabVIEW, examples using NI-TCLK can be found here: Help >> Find Examples… >> Hardware Input and Output >> Modular Instruments >> NI-FGEN >> Synchronization.
Eric Okawa
Applications Engineering
___________________________________________________________
Eric Matsumoto Okawa
"Draw a picture of yourself. Are you smiling?"
