07-19-2007 11:00 AM
07-20-2007 03:59 PM
Hi MeCoOp,
When creating a task in MAX, if you use sound pressure, it
is applying a scale factor for you. It
can output the data in dB’s. If you want
to use voltage and apply the scale factor yourself, then you will want to use Custom
Voltage with Excitation since your microphone will most likely need some sort
of excitation to work.
07-23-2007 09:20 AM
Well if you insist......My chassis has the PXI 8185 controller. Can I connect the 8185 directly to my laptop and communicate with the hardware through LabVIEW? I would like to be able to test my software/hardware interface before making an executable.
Thanks.
07-23-2007 06:02 PM
Hi MeCoOp,
If you want to interface with the hardware in our PXI
chassis, you will need to get something like the NI PXI-ExpressCard 8360.
The other option is to look at this knowledge base article.
Remote Laptop Control of PXI System
08-02-2007 10:07 AM
I've been having trouble building confidence with my results thus far. I wrote a simple vi to read from the 4462 and analyze the data. Currently I have two microphones set up in the reverberant room connected to the 4462. The problem I encounter is no matter what channel I select, meaning regardless if the channel has a microphone hooked up or not, the output in the form of total band power is the same. To futher illustrate my test set up I am using a pre-polarized PCB condenser microphone model 377B20 and a PCB microphone pre-amp model 426A11. I've also attached the simple read program that is giving me the aforementioned results.
Thanks in advance.
08-06-2007 01:23 AM
08-07-2007 09:15 AM
08-07-2007 04:16 PM
08-09-2007 11:56 AM
Nick,
I don't have anything availible to generate a signal. The microphone is powered through the IEPE sent from the 4462.
08-10-2007 04:43 PM
