Hi all ,
I am using SMU 4145. I have some register writes should be done with 100mA current limit and range but as I complete that I have to set to 100uA current limit and range to make a measurement.
so I have to repeat this for 10 times in the loop.
problem here is if i configure 100uA after 100mA SMU will give an error saying minimum is 1mA and cannot set 100uA limit and range .. every time I need to step down to 1mA limit and 1mA range than need to set to 100uA ..
than again while register writes I have to change range to 100mA than limit to 100mA
This I cannot repeat for 10 times .
Are there any way to switch between the limits and range?
Best Regards
Manasa M
