PXI
PXI-2586
I have four different boards
two boards testing at load 2.5A
and other boards testing at load 25A
we connect the load and PXI-2586 as attachment
It's connection any affecting on PXI-2586 at set load 25A?
(3,148 Views)
test these boards at different times...Smiley Wink
(3,141 Views)
Could you go into a little more detail on your hardware setup?  In your diagram, you correctly pointed out that the maximum current the PXI 2586 can switch is 12 A.  As long as you make sure you are not supplying the switch module with more than 12 A you should be ok.
Rod T.
(3,124 Views)
