04-29-2008 11:19 AM
04-29-2008 12:07 PM
Sorry for re-posting, I forgot to add that the card was replaced with a spare 6533 and the rack booted up normally, so I believe the issue lies with the card, not the rack or the slot.
How did the card control the boot up speed? Can it be instructed not to do that anymore?
04-30-2008 05:15 PM
Can you please confirm that not matter what slot the card (6533) is in ... the slow boot happens.
I also think reviewing the KnowledgeBase linked below will be helpful. Are you supplying signals to the card while the chassis is off?
KB 1K7IECLL: PCI-DIO-32HS (PCI-6533) Causes Power-on Problems with Some Motherboards
If this is not the case, then I would recommend trying to return the device for repair.
05-02-2008 12:08 PM
