I'm currently using a PXI-1000B chassis with a PCI-8156B Controller running Win 2k.I have 5 PXI modules installed.THe problem
is that the machine randomly reboots(restarts) itself.I currently am using the 150 watt supply I noticed that the max current on this
supply is 10 amps @ 3.3 vdc, my current requirement is 8.5 amps.Is it possible that the supply current could vary maybe below my
required 8.5 amps? Is it easy to monitor the DC voltages on this power supply? Is it the Controller and its relationship to the OS?
PS
I've already replaced the chassis and power supply once (died)
