PXI
PCI-8331 card - Windows 10 drivers
I am upgrading to a new PC with Windows 10 and the latest LabVIEW and TestStand from a PC with windows xp and LabVIEW 8.5.  My pxi chassis is PXI-1042Q.  Will I be able to run this or will I need to upgrade the card?
(3,475 Views)
This white paper is an excellent resource for determining what version of your products and drivers are compatable.
I would also recommend checking that your hardware is supported by the versions of the drivers you need. For instance, if you wanted to use the DAQmx 16.0 driver, check the readme to make sure that the devices you want to control with it are listed.
Dale S.
RF Systems Engineer - NI
(3,458 Views)
