PXI
NI-VST firmware version
How do I query the firmware version of a NI-VST module (specifically, the NI PXIe-5646R) from a C application?  I can see the firmware version in MAX, but this module doesn't support the niRFSA_revision_query or niRFSG_revision_query functions.
(4,261 Views)
I am Ed from National Instruments Applications Engineering. I have been researching into your query with regards to ascertaining the firmware version of the 5646R.
Unfortunately from what I can ascertain, you are correct in that this is an unsupported feature for this particular card. I was wondering what the application need was to require acquisition of said information programmatically?
Ed
(4,233 Views)
Ed, thanks.
Our procedures require us to record this information for all items of test gear used on customer products.
How does MAX retrieve the firmware version?
(4,231 Views)
Accepted by topic author Tevildo
This is indeed the case, thank you for broading the scope of the question, I was able to locate this community example for you:
https://decibel.ni.com/content/docs/DOC-41906
This uses System Configuration which is in fact NI MAX, that is to say that these VI's communicate with NI MAX to acquire hardware/software information.
(4,229 Views)
Thanks, that seems to work.  I've used nisyscfg.dll, as described at:
NI System Configuration 15.0 Function Reference
Is it possible to use nisyscfg to retrieve the device name (that is, the "Pxi2Slot3" name, not the model name), or do I still have to use niModInst for this?
(4,196 Views)
In order to do this I would suspect that this would be a property of the device, so call the function linked below, with the operation to read the property NISysCfgIndexedPropertyExpertUserAlias as explained in the second below linked document:
1. http://zone.ni.com/reference/en-XX/help/373242H-01/nisyscfgcvi/nisyscfggetresourceindexedproperty/
2. http://zone.ni.com/reference/en-XX/help/373242H-01/nisyscfgcvi/prop_indexrsc/
Ed
(4,180 Views)
Thanks again, that works.  The expert name to look for is "ni-vst", incidentally.
(4,177 Views)
