07-02-2016 07:56 PM
hi,
I'm using NI Scope PXI-5114, how do i get the x values (time increment) from measurements I/O -> NI scope for my graph.
Solved! Go to Solution.
07-02-2016 09:20 PM
For niScope Read, just choose the polymorphic case that outputs a waveform (or array of waveforms for multiple channels) and wire that up to your graph. The waveform data type inclues the start time and sample rate so the graph can figure out the X for you.
