05-21-2014 06:57 AM
Ok, we will check that until Friday (latest) and I will post the result here.
05-22-2014 06:27 AM
Hi again,
good news: we have tested the C-809.40 with NI-PXI 7350 and a PI stage (M-126.CG) connected and everything works as expected.
I hope that helps, if you need any further help please feel free to contact me again.
Gabriela
05-29-2014 11:40 AM
Hi Gabriela,
I'm thinking about using a setup that comprises a NI 7350 controller, a C-809.40 drive, a PI M-521.DG stage and a PI M-230 (servo) High Resolution Linear actuator. The stage and actuator will be interfaced to the C-809.40 drive and controlled using the NI 7350 controller. I'm asking because I want a set-up that will be relatively straight forward to integrate in addition to availablity of technical support if needed. Please let me know.
10-24-2014 09:09 AM
Hi Gabriela,
I purchased the C-809.40 drive along with M-231.17 PI stage. I also have a PI M-521 DG stage. I'm currently having difficulty controling these two stages using an NI PCI 7350 controller connected to the C-809.40.
For example, when I send a move command, I see position status changes in MAX but I don't observe any movement of the stage platform. I will appreciate any assistance you can render.
01-07-2015 02:44 AM
Hello SoIPS,
unfortunately, the messages which were supposed to inform me about new entries in this thread got stuck in my spam email folder. Doing some "cleaning work" today I found your question 😞
But I hope that all problems are resolved by now??
Gabriela
01-07-2015 06:51 AM
Yes, the problems have been resolved.
