07-26-2006 09:34 AM
08-17-2006 09:06 AM
I change my question.
I compiled C++ project witch uses *.so libraries. When I try to run it I get “Aborted” message and the application is terminated immediately:
[rflinux00] /user/vlezhebo/fesa2/ALLNIScope/v0/TEST > ALLNIScope_M.L86
Aborted
Using of the debugger gives me this:
Starting program: /nfs/slnfs1/vol1/u1/vlezhebo/fesa2/ALLNIScope/v0/TEST/ALLNIScope_M.L86
Reading symbols from shared object read from target memory...done.
Loaded system supplied DSO at 0xffffe000
[Thread debugging using libthread_db enabled]
[New Thread -1263582560 (LWP 879)]
Program received signal SIGABRT, Aborted.
[Switching to Thread -1263582560 (LWP 879)]
0xb4de1eef in raise () from /lib/tls/libc.so.6
Then stack is:
#0 0xb4de1eef in raise () from /lib/tls/libc.so.6
#1 0xb4de36f5 in abort () from /lib/tls/libc.so.6
#2 0xb522dc03 in ?? () from /dsrc/drivers/niscope51/L86/PRO/files/lib/libnipalu.so.1
#3 0xb4dc225c in ?? () from /lib/tls/libc.so.6
#4 0x00000000 in ?? ()
So, probably the problem is in “libnipalu.so.1” library.
What do I do wrong?
