12-06-2013 03:56 PM
i had the same issue. I fix it by installing MXI-Express BIOS Compatibility Software 1.4.1 and set the PCIE card on Mode 1
Read the Readme file for more details before installing the software.
http://download.ni.com/support/softlib//PXI/MXIe%20Compatibility%20Software/1.4.1/readme.html
08-25-2015 04:30 AM
Hi All, I,m fighting against the same problem.
What I have:
Chassis PXI 1000B
PXI-8330 inserted to 8th slot
PXI-6508 inserted to 7th slot
PCI-8330 in one PC PCI slot
I have tested these three different PC:
Thin client IGEL, Via processor 1Ghz with 1Gb RAM WinXPSP3
Fujitsu Scenic E600 Win2KSP4
PC with Asus M597A EVVO R2 mother board with AMD FX-8120-core WinXPSP3
I start the PXI chassis first.
Start the PC, but it hangs in black screen and no booting. When I stop the PXI chassis it boots normally.
The LEDs whilst the PC doesn´t boots are.
PXI-8330 POWER: GREEN
RX: Ambar
LINK: OFF
TX:OFF
PCI-8330 POWER:GREEN
LINK:GREEN
RX: OFF
TX:OFF
I have installed the MXI-115 driver prior to install the PCi card on the PC
I have tested several things, change the PXI-8330 to another slot, start PXI chassis with PXI-8330 alone, update the Bios of the third PC, change the PCI-8330 to anothe slot
Please can somebody help me?
To administrator, I have post the same message in another thread, so please remove conveniently
Thanks¡
08-25-2015 07:32 AM
did you tried what i did ?
08-25-2015 09:11 AM
The PXI-8330 needs to be in slot 1 for it to work with the PCI-8330.
08-25-2015 09:16 AM - edited 08-25-2015 09:16 AM
that doesn't matter... did you installed and tried the Compatibility Software ?
08-25-2015 09:18 AM
The compatibility software doesn't support MXI-3. It's only for newer generations.
08-25-2015 02:33 PM
.Hi Guys, thanks for your ideas
I have tried also with the PXI-8330 in slot1
The result is the same, the pc doesn,t start
08-25-2015 04:21 PM
With the PXI-8330 in slot 1 you should be getting green link and power LEDs. If not then you've got a hardware problem. I couldn't tell before if your LEDs were wrong because the PXI card wasn't in the controller slot.
I don't know whether it's one of the cards or the cable, though. Do you have any other copies of the hardware (PXI, PCI, cable) to swap with for debugging?
- Robert
08-26-2015 12:55 AM
Hi Robert, thaks for your comments
I have tested with the PXI-8330 in the slot1. The result is the same.
The thing is, if I have a hardware problem, which is the faulty card?. the PXI-8330 which has not the LINK LED in green?
Unfortunately I don´t have another hardware to do a check
Best Regards
08-26-2015 05:19 AM
Hi , I have tested the cable with a Fluke, not all of the pins give me continuity
The pin s are showing continuity are; 1, 3, 6, 8
