06-12-2015 07:22 AM
06-14-2015 09:14 PM
Would you please describe you problem in detail? Does the power led on PCI-8331 and PXI-8331 light normally when you powered them on? Did you use the standard MXI-4 cable? Making your own cables could cause communication errors like you are seeing. Have you installed the drivers required for MXI-4 (PCI-PCI Bridge and MXI connector monitor)? Information for the drivers is shown in the following link:
http://digital.ni.com/public.nsf/allkb/6E8F66D201130C5A862575CF004D10DF
In addition, you can eliminate that cable as a source of error by either getting a new MXI-4 cable or using this custom cable on another MXI-4 PXI setup and verifying normal operation.
06-15-2015 09:45 AM
06-15-2015 10:17 AM
Are any other LEDs lit (Rx, Tx)? Usually one is lit when it's trying to link but can't, like when the cable is bad.
Some motherboards don't provide 3.3V to PCI slots, which the PCI-8331 requires. On 2004/2005-era hardware (189051A-01, 189051B-01) the power good LED circuitry had a flaw which caused it to light up when 3.3V wasn't present. Is your PCI card one of those numbers?
Also, the drivers for MXI-4 don't affect linking.
- Robert
