PXI
MXI-4 Cable Definition
Hello all,
I'm setting up a PXI chassis using a remote controller and MXI-4 cable.  I don't have the luxury of routing directly from the remote controller card to the PXI chassis, and have to go through a bulkhead.  I haven't found any COTS bulkheads for the MXI-4 cables, nor a MXI-4 cable definition.
Do any of you have access to an MXI-4 cable definition?
(2,983 Views)
Hi Mitchell,
Could you provide a bit more information on which particular cable you are using and why you're unable to route it directly, is it a length limitation or what? I'm afraid I'm also not quite sure what you mean by cable definition, are you looking for the pinout as discussed here, or some other information?
Thanks!
Selene
(2,956 Views)
