06-11-2016 09:38 AM
How do I control a PXI-2506 26.5 GHz Dual 6x1 Mux within PXI-1042 chassis a from 'C' code with a minimum of drivers? We want to use our own code, not LabView, just plain 'C'. We also prefer to use our own embedded (Linix based) controller without a slot for a PXI card (if possible). Like is there a simple serial interface or ethernet interface to control the boards hosted in the PXI-1042 chassis? The switching speed is very low, this is a part of a manufacturing test system, we want to use the PXI-1042 with several 6x1 Mux inside for RF switching of instruments into DUT's.
06-14-2016 04:40 AM
Hi eirlund,
In answer to your questions:
Is there a simple serial interface or ethernet interface to control the boards hosted in the PXI-1042 chassis?
We also prefer to use our own embedded (Linux based) controller without a slot for a PXI card (if possible)
I hope this information gives you somewhere to start for looking into whether what you want to do is feasible?
Joe
