I am trying to have an FPGA module (PXI-7831R) produce a trigger on the PXI bus to begin a pulse generation using DAQMX (6052E) from the rising edge of the PXI trigger. The problem is I have to produce a trigger on the first iteration of a single-cycled-loop on the FPGA monitoring the pulses of an encoder (essentially the encoder count). For some reason, the PXI trigger is high in its idle state, so the first trigger doesn't produce an edge because its a high-to-high transition causing the 6052E to miss the first pulse generation. The option to set the PXI trigger line low from the FPGA prior to entering the loop is out of question, because the FPGA produces a compile error stating that you can't set the line outside the single-cycled-loop. So that leaves me one option, set it in MAX or somewhere else, maybe using the 6052E????
Arindam
