PXI
Is there a manual for the PXI-5610?
All the information about the PXI-5610 leads to manuals and datasheets about the PXI-567x series. Is this the only information about this unit or are there datasheets and manuals specific to the PXI-5610.
(4,090 Views)
Hello Ryan,
As noted in this post, the PXI-5610 is part of the PXI-567x series RFSG devices and, as such, is documented in the "NI PXI-567X Specification" here and the NI RF Signal Generators Getting Started Guide here. Is there anything specific that you were looking for?
Matt Anderson
Hardware Services Marketing Manager
(4,083 Views)
I want to do some amplifier IMD testing and have 1x PXI-5652 but need a 2nd generator. Can PXI-5610 be used with RFSG SFP by itself ie: without an AWG (5421/5441/5442)  to generate CW?
(2,691 Views)
Chris,
I would recommend opening a new thread for this question to get more visibility since this thread is 12 years old. To answer your question though, I don't believe a 5610 will be able to generate a CW by itself since it is just an RF upconverter. You would need a separate signal generator to produce an IF signal before upconverting it with the 5610.
Best,
Daniel
Applications Engineering
(2,679 Views)
Thanks Daniel
(2,674 Views)
