08-09-2006 07:10 AM
08-09-2006 09:33 AM
08-10-2006 01:58 AM
Hey James,
A good pointer you gave!
I read the user manual of PXIe 1062Q
Guess what??
It does exactly what I was looking for
A extract from user manual:
"If the inhibit switch LED is steady red, the system fans or power supply
fan has failed. The remaining fans will automatically be driven high.
Note
If both system fans or the power supply fan fails the chassis will shut downautomatically, preventing the chassis and modules from damage due to overheating."
Thank you!
Regards
Dev
08-10-2006 10:21 PM
08-11-2006 05:11 AM
Hi Tica,
Thanks for that Link!
As I told, in that particular case I was a mere spectator and it came to my knowledge only after the disaster stuck!
Well, in the end that was a lesson learnt the hard way by the Rack fabricators and system designers
Shall definitely use that link in future, in case I come across any more instances of exemplary idiocy.
Be it by me or others
Regards
Dev
08-11-2006 02:08 PM
I just wanted to jump in on this conversation and add to Tica's answer by mentioning PXI Express. The PXIe specification includes a System Management bus (SMbus) which is found on all modern PC's. The bus allows the PXIe controller to talk to the fan controller and temperature monitoring devices, and will allow us in the future to add all sorts of useful features to chassis, such as fan speed/fail monitoring, temperature monitoring/shutdown, power supply health and over/under voltage monitoring. It will be possible to monitor this both locally (such as inside a LabVIEW application) as well as remote monitoring and reporting.
We know from anecdotal discussions that customers can accidentally overtemp systems due to poor air circulation, excessively hot days or other factors. Like any piece of equipment that can dissipate upwards of 600W in the case of an 18 slot chassis, good airflow is imperative to proper operation. Recall we spec all PXI chassis for 0-55C ambient temperatures, meaning internal temperatures on modules will be a lot hotter, whilst still within manufacturers rated temperatures.
- Tim F, Hardware Product Strategist, Instrument Control Group.
