PXI
Is it possible to calibrate PCI cards using Calibration Executive if Cal Exec is installed on a PXI controller?
(3,042 Views)
As far as I understand, this is not possible.  One option would be to use a MXI to connect a remote PC controller and PCI device to the PXI chassis where you might already have PXI devices to interface with the other test equipement needed for the procedure.  However, this option does not include the actual PXI controller.
PC Control of PXI
Samantha
(3,029 Views)
PXI, USB-Daq, SCXI, cDaq ----- Yes,        PCI would require a PXI-PCI Bridge and ISA/PCI Daughter-Board  or pci-pxi adapter, MXI-3 or 4 wouldn't do it your CPU's would be fighting for the Bus.
See This for more info
http://digital.ni.com/public.nsf/allkb/219E270A357C37AE86256BF4006C16CB
(2,507 Views)
