02-24-2012 07:10 PM
Dear,
I am working on implementing dynamic systems modeled ordinary differential equations on PXI-7811R FPGA using labview FPGA. Is there any body who can help me how to implement differential equation on PXI devices uding Labview FPGA, please? Is there any integrator in Labview FPGA, module. I used Discrete Integerator in LAbview FPGA module in Maths palette, but i hesistated if it really works . I really appreciate your help,
Gammee
02-27-2012 04:57 PM
Thank you for posting on the discussion forum.
You can solve differential equations using LabVIEW FPGA but you may run into some significant difficulties in doing so. If you are not tied to using FPGA, you could try using LabVIEW real-time, which may make things much easier. But if you would like to stick with FPGA, see the link below for a list of examples that may be helpful:
Below is a link that you can review to better understand the functionality of the discrete integrator should you choose to go that route:
http://zone.ni.com/reference/en-XX/help/371599B-01/lvfpga/discrete_normalized_integrator/
I hope that helps.
Best,
Rachel
