Aaron,
I won't be able to provide the password for the VI because the source is NI Confidential. I can, however, give you the library name. You can find niModInst.h in <IVI directory>\Include\ and niModInst.lib in <IVI directory>\Lib\msc\. You can also find much more detailed information and function references in the NI Signal Generators Help under NI Signal Generators Help » Programming » NI-FGEN Help » NI-FGEN LabVIEW Reference » VIs » Utility » NI-ModInst Help.
Message Edited by Chris_D on
01-14-2008 11:54 AM
Chris Delvizis
