01-15-2008 01:01 PM
01-15-2008 02:12 PM
If your PXI system contains a third-party bridging solution, you must enable this option to see your third-party bridge as a bus. Once you enable this option, you can create a chassis from the bus and identify it. By default, this option is not enabled.
To show PXI buses, right-click your PXI system and select Show PXI Buses. You should now see all buses that MAX knows about in your PXI system.
01-15-2008 02:16 PM
PXI buses represent the internal PCI-to-PCI bridge hierarchy for your PXI system. The configuration tree represents the buses, using information about which buses are subordinates of other buses. Any bus identified as a chassis (such as a chassis connected by National Instruments MXI bridging solutions) is now shown as a chassis, rather than a bus. You must identify third-party PCI-to-PCI bridges that connect to PXI chassis before configuring the chassis. You may see other PXI buses in your PXI system. These buses are PCI-to-PCI bridges internal to your computer or bridges on multifunction devices, and should not be identified as chassis.
You can identify your PXI bus as a chassis.
Identify my PXI bus as a chassis
Right-click the PXI bus that represents your third-party PCI-to-PCI bridge to a chassis and select Identify as a PXI chassis
01-15-2008 02:20 PM
If your PXI system uses a third-party bridging solution, MAX cannot detect the presence of a PXI chassis automatically. To identify a PXI chassis connected by a third-party bridge, complete the following steps.
You can hide the PXI bus objects again by right-clicking the PXI System node and selecting Show PXI Buses to uncheck the option. By default, MAX does not show PXI buses in your PXI system.
01-15-2008 02:30 PM
01-17-2008 10:25 AM
Hi Andy,
We try to make our software as versatile as possible, in terms of interacting with third party hardware. Even so, it is impossible for us to create specific files for every system that may interact with it. If a third party chassis follows PXI specifications and includes the necessary ini files, then it should be able to interface with our software.
The Keithley chassis you are trying to detect should be able to communicate successfully. My guess at this point is that the pxisys.ini file may have somehow become corrupted. You may want to try removing this file and restarting the system. In order to do this, navigate to C:\Documents and Settings\All Users\Application Data\National Instruments\MAX\Data, and rename the Data file. Then delete the pxisys.ini file in the Windows directory and restart the system. Hopefully, after launching MAX, the chassis can be identified properly.
Keep me updated on everything, and we will try to do everything we can to make our software an open platform.
Lauren L.
01-17-2008 01:31 PM
01-18-2008 12:50 PM
Hi Andy,
You can file a product suggestion by selecting "feedback" in the Contact NI section of our website. I will go ahead and make a suggestion myself, but I recommend that you file one as well. We take customer feedback very seriously, so we like to know what you are looking for in our products.
Lauren
