04-07-2006 01:55 PM
04-10-2006 10:48 AM
Hello!
If you want to create a case structure to handle arbitrary integer values, you can always use the decimal representation of the hex value (i.e. instead of 0x00FF, use 255). If you want to create cases for the hex values, you can right-click on the case structure, and choose Radix>>Hex. You should notice that all cases are now preceded with an 'x' to denote hex values. This will allow you to create cases called x00FF, which sounds like what you're looking for.
04-10-2006 11:32 AM
04-11-2006 08:32 AM
