NI Home
Cart Cart | Help
You are here:
PXI
Reply
Member
Jimmy@Funny
How to sync a simulate card with a real card
Hi all:
I have only one  6124 on hand and installed in a 1073 chassis.
But my project finally need two 6124 for data acquisition. I am developing software for it, so I just want to test the performance of sync two cards, but the problem occurs every time I try to start the two tasks.
I just download the sample from http://www.ni.com/white-paper/3615/en  and tried Figure 6 example on my PC, same error occurs. It is said I can't use a simulated device to work together with a real device, or can any one provide me some solution to it.
Thx in advance.
The error message occured is:
No registered trigger lines could be found between the devices in the route.
If you have a PXI chassis, identify the chassis correctly in MAX, and make sure it has been configured properly. If you are using PCI devices, make sure they are connected with a RTSI cable and that the RTSI cable is registered in MAX. Otherwise, make sure there is an available trigger line on the trigger bus shared between the devices
Source Device: PXI1Slot2  (a real 6124 device, run in master task)
Destination Device: PXI1Slot3 (a simulated device, run in slave task)
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
