PXI
How to route front panel trigger(PXIe-8108)to the backplane (PXIe-1075 chassis)
Manual for 8108 says the front panel SMB connector "Trig" can be routed to the backplane trigger lines, e.g. PXI_Trig0 , but it does not say how to configure that. Can it be done in NI-MAX? or shall I write my own vi doing that ? I would like to use the port as a master trigger for cards in the PXI crate. Please let me know if you have any idea. Thanks!
(2,636 Views)
I have a similar question. I heared there is some "beta" vi for this.
Can anybody help?
(1,522 Views)
You can do this with the DAQmx Signal Routing VIs or by pointing to the controller's SMB port with a property node. See the following KB for more detailed information:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VUOSA2&l=en-US
(1,509 Views)
