04-13-2006 09:18 AM
04-18-2006 07:37 AM
Hi HH,
Unfortunately there isn't any way of programmatically getting the serial number of the chassis itself. The controller/ cards etc yes, but not the actual chassis.
It'll have to be the Mk 1 eyeball I'm afraid.
Thanx
AdamB
01-09-2008 10:39 AM
01-10-2008 10:19 AM
Hi
unfortunately using either Max or labVIEW you are not able to programmaticly acquire the serial number of either the controller or the chassis from a PXI system but you are able to acquire the serial numbers for the cards within the system.
Devices selected in max should display their serial number when selected. If you are trying to show these serial numbers within labVIEW then you can use the DAQmx Device Property Node this should have a configurable option to select serial number for any visable device on your system.
Below is a link to a knowledge base which explains this node in more detail
http://digital.ni.com/public.nsf/allkb/92F3F7C79579FA238625718700764F9D?OpenDocument
I hope this is helpfull to you - if you have any further queries or you still cannot display the serial numbers you desire post back and I will endeavor to help further
01-10-2008 11:37 AM
01-11-2008 03:52 AM
