PXI
How to keep OI window in background with message box/pop up boxes on top.
Hi
I have a new requirement to add in OI .How to keep OI main window fixed in the background with message pop ups atop OI window.
Even  with message box pop ups , i should not have the access to OI main window.To  make it more clear,when i change to some other application in my PC task bar (for eg:-MSWord) and then click back to OI main window ,i should see the message box on the top of OI main window . I should not  have the access to click OI main window and OI message box as two separate operation in the task bar.
Please let me know where i need to make changes in my OI  codeset.
Nand
(2,814 Views)
Hi Nand,
In the Message Popup step settings, check Make Modal under Layout >> Dialog Options.
I hope this helps.
Cheers,
David Goldberg
Software R&D
(2,796 Views)
