I am developing an application by using LabVIEW 8.2 and RealTime. There is a host PC connecting to a PXI through network cable. Application VIs are running at PXI and GUi is running at host PC. My problem is When I config a boolean control as "Latch when release" mechanism, pass it to a shared network variable and then to a boolean control at PXI. "Latch when release" mechanism seems not run very well. Most of the time, no action when I press the boolean control button in my GUI. It seems that shared network variable could not act as "Latch when release" mechanism. I checked some examples from NI. Most of examples set the boolean control button mechanism as "Switch when press" and manually switch it status later on. I have a bunch of such boolean control buttons in my GUI. It will be hard to handle every of them in this way. I'd like to know whether there is an easier solution for this.
