03-03-2008 07:38 PM
03-04-2008 07:25 PM
Hi Hollister,
The PXI-4110 Power Supply comes with a screw terminal block in place where the Auxiliary Power Supply connects. In order to plug the Auxiliary Power Supply in, you will first need to remove the terminal block by unscrewing the screws on either side and then you will be able to pull the terminal block off. The plug of the Auxiliary Power Supply will then fit into the revealed socket.
With regards to the cable that will connect the Auxiliary Power Supply to the 115 VAC input power, the Auxiliary Power Supply does not come with one but you can use a standard IEC Power Cable. This is same type of power cable that most computers use.
I hope this explanation helps, Mallori M.
03-04-2008 07:57 PM
This answered my question.
