PXI
How can I communicate PXI-6509 by Static DIO Register-Level Programming?
- How can I communicate PXI-6509 by Static DIO Register-Level Programming?
  PXI-6509 physically Port0 is connected to Port1.
  For checking all connections are correct for this case so I have used DAQmx Test Panel. Just in case everything is ok.
  In this case I interested in to communicate the PXI6509 by Register-Level Programming.
  I have tried to use Open VISA Test Panel for sending and reading data (in MAX explorer) and
  use NI-Spy for checking communication data.
  The first step I configured Port0 to Outputs state and Port1 to Inputs state.
  The second step I setup Port0 to 0xAA.
  The third step I read back Port1 and expected data will be 0xAA but just only 0x0. Why???
   1              ViOut8(0x03D83318, 10, 0x00000041, 1)
(2,904 Views)
Hello!
We don't do support on register-level programming but the problem you are experiencing might be due to tri-state on the ports?
Please check this manual that covers register programming of the device you are using:
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,850 Views)
