PXI
FPGA
I'm tring to program a PXI-7841R. It is mounted on a PXIe-1085 and is connected to a SCB-68A.
I'm trying to read the analog output channels with my multimeter but i'm always reading 0 even though the channels seems to be "activated". Their impedance is low.
The DO are working fine, thus I think i'm missing something trivial but I can't figure out what. I'm new with labview. I'll attach a printscreen of my test program.
Thank you for your help.
(3,258 Views)
Accepted by topic author snostro
You are only telling the bit value for the analog output.  Since the analog outputs are -10V to +10V, you have a 20V range over 16 bits.  Therefore a single bit is 20/(2^16)=~300uV.  Most DMMs will not see that unless you have a low range.  So if you want 3V, you need to write 3*(2^16)/20=9830
GCentral
(3,245 Views)
