04-09-2017 10:14 PM
We are using NI-PXIe-1075, Signal Generator module NI PXI 5652. We are encountering a problem regarding the modules. It says that one of the modules is not being recognized by LabVIEW (AWG name missing/not recognized). But we checked the hardware module and it is properly inserted in the PXI. Do you know any other causes for this error? Thank you.
04-11-2017 10:11 AM
Hi eeestudent2017,
Does the device show up at all in NI MAX (possibly under an unrecognizable ID)? If so, when you run a self test on the module in NI MAX what does it return? If you switch slots does the same behavior occur?
