Labview v8.5
Using FTP Get Buffer.vi to retrieve the contents of a file generates the following error
Code: 11 (Too many files open)
Error TCP Open Connection in FTP Open Session.vi->FTP Get Multiple Files and Buffers.vi->FTP Get Buffer.vi->read train report file.vi->MASTER.vi
Three machines in the system
A: Labview executable running on XP ( typical PC hardware)
B: PXI machine running Labview RT (where problem occurs)
C: Labview executable running on XP (typical PC hardware)
Machine A is regularly ( 30s interval) ftp'ing back a single file from machine B.
Machine B occasionally is occasionally ftp'ing back two consecutive files from machine C (one after the other)
Machine B fails with above message. Can occur soon after a reboot, or after a considereable time after a reboot.
Once failure has occurred, attempting to ftp in to machine B results in failure as well.
Rest of machine B appears to operate as normal ( including shared variables ).
We have deployed similar scenarios (with previous versions of labview) and have not encountered this problem.
Possible options we have considered without success (so far):
* Problem occurs when ftp in to machine B occurs whilst ftp from machine B is also occurring.
* File open handles are running low and occasionally running out
Other questions/comments:
* Have noted an ftp related bug in the 8.5 release notes - is there other acknowledged bugs in ftp ?
* Can we monitor (programmatically) on RT system number of used file handles/set number of file handles ?
* Since the whole open/ read/close operation occurs within the single FTP_ReadBuffer.vi, it is hard to see that we are somehow leaving a file open.Apart from ftp'ing, there is some, but little, file access occuring on machine B.
