01-24-2007 04:09 AM
01-29-2007 09:43 AM
01-29-2007 10:06 AM
Hi Vedis,
Are you using the 5660 demo panel or the RFSA Demo panel example located here:-
C:\Program Files\National Instruments\LabVIEW 8.2\examples\instr\niRFSA.
from the programs>>National Instruments>>RFSA you can see the 5660 demo panel, this will not work with the 5661 you would need to continue to >>Examples>>LabVIEW 8.2 then you will see the RFSA Demo panel example folder. The 5661 demo panel is located there.
Hope this helps,
Nick
01-29-2007 10:54 AM
Hi Nick
I was actually using the "5660 demo panel". Is there a stand-alone RFSA Demo panel for 5661, which is independent of Labview? We are not using Labview, but C, sorry 🙂
Cheers, Vedis
01-30-2007 02:57 AM
Hi Vedis,
Sorry but as far as I am aware there is not a standalone application SFP for the 5661 only the LabVIEW example.
Nick
